I would like some advice about mould coming through a newly laid laminate flooring.
The house was built in the 1920s. We have undertaken some major renovation. Taking each room back to the brick. The dining room floor had a laminate laid which we lifted. The floor underneath was concrete with very old tiles in some areas. We used self levelling to even out the floor allowed it to dry out and laid a new laminate. Yesterday I noticed all around the skirting of the walls that mould was coming up through the joins of the laminate flooring. The flooring was layed on 9th August. We also had a DPC put into the property.
I have a few thoughts:
1. The self levelling hasn't dried enough - it looked and felt dry and was dusty.
2. The concrete under the self level is causing the issue - however the original laminate was absolutely fine, no mould on it when lifted
Could laying the self levelling have caused a problem with the original concrete under it?
I don't know how to approach the mould, do I lift the laminate and see what's going on underneath or do I treat it with an anti fungal spray and see if it comes back?
Thanks for the help
Thanks for the help
