Shower Pump to powerful???
27 Jun 2017
Hi
I recently had my bathrooms refitted (main bathroom, en-suite and downstairs toilet). I have a gravity fed system, and based on the size of the showerheads (8 inches wide) I was advised to get a 3bar shower pump (by Salamander), however now I find the pressure is really high water is really fast in my hot water. Is there any way I can reduce the pressure? Or do I need to replace the brand new shower pump with maybe a 2 bar or even 1.8??
Don't turn the shower on full, just turn it on half way
Other than that, yes you'll need to replace the pump
Thank you for replying, the shower is fine not a problem just a couple of taps and the douches I have fitted there is far too much pressure and if the douche is left on after a while water will start to leak out.
I have been informed a pressure regulator could be fitted but I have no idea what this is or how it would work.
Ideally I don't want to change the pump as it costs me quite a bit and only been fitted 2 weeks I wouldn't be able to return it now
What about a 15mm to 8mm reduction before the tap and then back again?
Not sure if I have missed something here but a shower pump should be fitted into the shower feed. that way it would only come on if the shower is used and not when you turn on a tap.
I wanted to improve the water pressure (especially the hot water) throughout the house, as my hot water pressure is very low. He feels the 3 bar pump as advised by Salamander. When. The shower pump is turned off the water just trickles out of the taps
Don't worry your salamander pump wont stay powerful for long. Particularly if its not been installed close to your hot water tank.
Provided the shower pump is specified for use to supply other taps then it's a common practice to boost other outlets.
If taps are leaking at 3 bar they are defective. 3 bar is nothing unusual, mains supplied hot water systems operate around that pressure. Cold mains supplies are often higher than that, up to 10 bar in some areas.
