Hi Shadrack
Check to see if the existing ceiling is sound, and could hold an extra coat of plaster. If not, your options would be to pull it down (v. messy), or overboard with 12.5mm plasterboard and then skim multifinish.
If the existing ceiling is sound, you can overskim with multifinish, but it will need glueing (apply PVA:water 1:2) and before the glue dries, hit it with your first coat. The PVA will glue will ensure the first skim coat is firmly bonded to the ceiling.
... or get a pro in! Probably cost £150 ish?
Hope that helps ....
