I have a wooden fence, 6ft panels with 75mm wooden posts, that has partially blown over in the recent weather. Much of the rest of the fence is in good condition, either more recently replaced, or in better drained soil.
I'd like to use slotted concrete posts to replace the rotted wooden ones, but I note that they slightly narrower across the slot (50mm) than the wood I am replacing (75mm). I was hoping that I could simply replace them and then as other parts of the fence failed in time, replace those with concrete too, until I had a completely concrete post fence with easy to replace wooden panels. But that will only work if the spacing for concrete posts is the same as the spacing for the existing wooden posts. So the question is, does the spacing need to change, or is the 25mm difference simply for clearance to allow the panels to fit easily and I am okay to just put the posts in the existing holes?
