Hi all, i'm trying to sort my wiring out on my phones.. now i know that i'm not meant to touch anything before the master socket, and i'm trying to avoid it.. but i'm also trying to avoid BT's inflated callout charges..
Heres how the wiring was set up when we moved in to the house... the house was built in the mid eighties.
- Main junction point outside the front door.
- One extension point with wiring outside the building going to the pantry/cupboard (of all the stupid places) with a master socket on it.
- Another standard extension socket going upstairs, coming directly from the main junction box, also wired in directly to the main orange and white wires (similar to the master).
Ie what we've got is two phone points, both wired directly to the main feed, one is a master, and the other isnt. Both are BT stamped sockets
So, first off , is this a weird way of doing it? I thought all extensions should come from the master socket?
Anyway, that aside, i had to take the master socket off when we were decorating.. now it doesnt appear to want to work again when i wire it up. The socket upstairs is still fine (as you'd expect cause its wired direct) so we've just been using that. ie there is currently no master on the line.
Also, the outside junction box needs rewiring.. its pretty shabbily done and there is a completely loose connection (the main white wire) which cuts everything dead, i've pushed it back in to make it work okay but its not crimped in.
So, if i ring BT, can i just say that we have an intermittent fault, they'll come out, suss the wiring fault in the main junction box, suss that the masters are wired wrong (or missing).. and not charge me? I was also thinking of just saying that the master was never there, and that the wires were just loose when we moved in..
I KNOW i shouldn't have taken the master off, but i also know that the wiring is crap in the junction box, and that wasnt down to me.
What are my options? If i didnt need to improve my broadband speeds, i'd just leave it, but i think the dodgy wiring is throttling me.
Thanks...
Thanks...
