- Joined
- 18 Sep 2020
- Messages
- 11
- Reaction score
- 0
- Country
In my new home I have a single coaxial cable heading from outside to inside box where it meets coaxial cables running to TV/Radio sockets installed in all rooms. I am planning to install DAB, FM, DVB antennas using triplexer/combiner and satellite dish with with two LNBs attached to splitter or diseqc switch. What I need is advise that equipment to use to make it working properly.
As a triplexer/combier I'd like to use for instance:
https://cpc.farnell.com/optima/114212/outdoor-fm-dabuhf-tv-triplexer/dp/AP03518
Then for satellite LNBs:
https://www.inverto.tv/lnb/206/twin-4-feed-lnb-for-90e-130e-1920e-and-2350e-for-80cm-dish
+ another one to cover 28.2+28.5 positions.
What should I use to combine/sum the triplexer with satellite signal?
https://www.amazon.co.uk/dp/B00GG343VW/ref=cm_sw_r_awdo_navT_g_BDWA992E9NQA2AJE51RF
or I should use something else?
Also is it possible to cover 28.2 and 28.5 with single LNB converter assuming 80cm dish?
What should I use in the cable box at home to distribute the signal?
regards,
regards,
