I have a Premier Elite 640 with approx 80 zones all powered from the main panel.
For testing, no bells are connected, no other power sources to the expanders, no batteries in any zones.
*Without* the panel battery connected, the system current is stable at 1.9A
With the panel battery connected, the system current decreases down to 1.5A for 10s approx every minute as reported by Wintex. It is not at the same time every minute, and sometimes it repeats after 30s. The 10s is quite consistent though.
This may be related, but the reason I started investingating is because the keypad brightness drops slightly for 2 seconds every 28 seconds. This is consistent.
I have just replaced the battery with a different one (not new though) and the same behaviour continues. The battery is charging though.
The panel has been in place for about 4 years.
I suspect I'm at the limit of the PSU, and should power some of the networks separately? The bells were configured as SCBs, so as not to consume too much current when sounding.
Does the system current include the battery charging current? I guess not otherwise it would go up when I connect the battery.
Any confirmation or disagreement much appreciated!
