Is that because it contains PVA ???
No. Gardz iz an acrylic resin which does not contain PVA.
On the subject of PVA, it is not strictly the PVA that we use as an adhesive/sealer that is used in vinyl/latex paints. In most instances, PVA - Poly(vinyl acetate) is used, but first has to be combined with Poly(vinyl alcohol) to create a copolymer - Poly(vinyl alcohol-co-vinyl acetate) - in order for it to be compatible with the solvent within the paint, which contains poly(methyl methacrylate).
Without these polymers/copolymers working together, we would have a paint which would not mix or dry properly.
This is the reason why I try to encourage people to avoid adding standard PVA to water based paints when they are hoping to make it tougher/adhere better - in many cases, the PVA can either ball up in the paint and cause a problem, or it will not dry correctly.
As for the comment on Zinsser products, I have to admit that I do tend to plug them quite a bit on here, but for very good reason.
Having spent years doing things the 'old fashioned' way, I certainly understand the argument for not using the products and just using elbow grease. However, as a professional decorator, it more than makes sense to use them as much as possible - financially, physically and timewise, in order to provide a competitive professional service, and I was happy to see them arrive.
They are only truly essential products in some problem cases because, for those doing DIY, there are usually no time/labour constraints meaning money saving is a valid point, but, if they can solve a problem quicker, why not use them?
The main reason I, and many others, recommend them here is purely to make life easier for the person who is looking for help/advice - who doesn't want to make tedious tasks as easy as possible for themselves?
It does surprise me that Zinsser seems to have cornered the market with these 'problem solving' products, and I often wonder why other manufacturers haven't cottoned on that there is money to be made by producing similar products of their own. I suppose competition would drive prices down, meaning profit margins wouldn't be as high, but it doesn't seem to stop other markets copying each other.
