- Joined
- 29 Aug 2020
- Messages
- 104
- Reaction score
- 5
- Country
Has anyone replaced a bath panel on a corner bath with tongue and groove ?
Is so is it very difficult?
Many thanks
Many thanks
Sounds interesting, is it hard to work with ?Uvpc t&g , waterproof and in many colours .
Very easy .Very cheap .Sounds interesting, is it hard to work with ?
Roofing , uvpc suppliers, builders merchants ( Selco, Wickes stock).Where do you buy that plastic?
That’s why you rip the back cells so it’s only a thin sheet to bend.the trouble you have with plastic when you try to bend it the back wall can concertina on one or more sections and you then get a crease at the front where it changes angles
I cut every one , no problem, still plenty of resistance.indeed but better to cut perhaps every third or fourth to give a gradual angle change as if you cut too many there is little or no resistance to folding near to flat causing a virtually uncontrolled reduction in outer surface form ??
thanks for the feed back very helpfulI cut every one , no problem, still plenty of resistance.
