TV socket for cable TV ( Virgin)
mam
30 Jan 2022
Hi Forum,
I would like to move my virgin system to another room w/o really moving the old NTL TV socket which contains a Qamtex VC330 TV/FM isolator (5-1000Mhz)
Could I use a "standard" TV / FM/DAB TV socket instead with Coax connector like the below ?
https://www.screwfix.com/p/labgear-coax-male-to-f-plug-male-adaptor-10-pack/39772
As far as I understood Cable TV signals and Freeview aerial use the same bands i.e. would a standard socket work ?
Thank you
Markus
First you are not supposed to touch anything to do with a Virgin installation. The old NTL socket has safety isolation components in it to prevent the VM system becoming live at 240V if your equipment develops a fault. So it is good you are not planning to move it. I guess you just want to run an extension to another room.
You MUST use a fully screened TV socket, not the £1.50 ones in the DIY sheds. You MUST decent double screened cable such as WF100 and you MUST use decent F connectors either crimp or compression. The reason for this is to prevent ingress or egress of VM signals. VM signals are in and beyond the TV bands and any egress or their signals could cause harmful interference to other users. Any ingress of signals will give you interference.
