- Joined
- 5 Apr 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hi there,
I've excavated a channel for a garden path and am looking to use a large number of quite large and heavy rocks (size of a football to perhaps 2ft by 2ft) I've reclaimed from an old garden dry stone wall for edging. I've found nothing on how to approach this but my intention was type 1 then gravel.
My issue is when to lay out the edging. Before the first layer of MOT and i may not be able to compact between the gaps in the rocks but i also don't want to risk the MOT breaking apart because the edging isn't containing it from the base.
How should i go about this? It was suggested i should lay half the sub base, lay the edging and then the remainder of the sub base but i wonder if that first layer would break apart because it's just on the ground with nothing containing it.
Thoughts most welcome but I do want to use the rocks... buying dedicated edging isn't really a option.
Thanks!
Thanks!
