Vent Covers on Air Bricks
10 Feb 2024
Hi all, we’ve got an old house with suspended flooring that has airbricks throughout. Problem is the bricks are quite close to the ground (only 1 brick above in some cases) and we’re getting quite a bit of splash back into the airbricks when it rains, so I was thinking of installing some vent covers to reduce the splash back whilst still letting the air circulate underneath, but I don’t want to significantly reduce the air flow. Has anyone done something similar or could advise?
Vent covers I’ve found are here:
Thanks in advance.
Thanks in advance.
I would guess that airflow will be significantly reduced. I have no idea if the reduction will cause problems.
