Hello everybody!
I’ve just removed peeling lining paper from the walls of my living room and I’m now left with quite a lot of paste residue on the walls. I’ve just about resigned myself to steaming/scraping/sugar soaping the paste off as best as possible but just noticed a product that might save me the bother:
http://www.decoratingdirect.co.uk/viewprod/z/ZINSSER_GARDZ_CLEAR_INTERIOR_WALL_SEALER/
Can I coat the walls in this and then paint straight over the top with emulsion? I’ve got some cheap white Contract Matt to go on as a first coat (after the Zinsser Gardz) which I was going to water down, before applying the top coats (Valspar Premium Matt).
If I need to prep the walls (filler/sand) do I need to do this before applying the Zinsser Gardz or can the prep be done after? If possible, I’d like to treat the walls with the Zinsser Gardz, put on a mist coat of the white Contract Matt to show up the areas which need filling/sanding/prepping, then once prepped, apply the top coats?
If I do it in this order do I run the risk of possibly sanding off the Zinsser Gardz and exposing the paste residue beneath?
walty666
walty666
