Washing machine not running program after tripping RCD
2 Sep 2015
Bosch Classixx Vario Perfect - WAE28166GB
The machine tripped the RCD whilst running a cycle. Since then it will not start any programs.
When pressing start the buttons light turns solid (as it should) but the machine does nothing else. At this point it should start drawing water in.
No flashing error lights/codes
Door switch has been swapped out - no change
Water inlet has been disconnected and has good water flow
Any one having guidance on which areas i should be checking next?
Pressure switch?
Inlet valve?
Drain pump?
Many thanks.
Steve
Pressure switch?
Inlet valve?
Drain pump?
I would guess at a main processor board complete failure, but not easy with no fault indications showing. There is some expertise on the whitegoods forum.
