What is '1.6Nm' like?
6 May 2011
Can i, a robust 1.8m tall male, achieve this torque with a hand held 8 inch long straight screwdriver held at chest height ? How about a battery powered drill with phillips head? How to judge, or estimate, this measurement without a torque meter? thanks Will be tightening up the MCB supply cable fittings.
1.6 Newton Metres is the same as 1.2 foot-pounds. This is actually quite a low torque, equivalent to having a lever 14 inches long and hanging a full jam jar on the end. So it sounds like just "nip it up".
Never use a powered drill or screwdriver in a CU. If it jumps you will ruin the heads and won't be able to tighten or remove the screws.
