Hi all,
I've got 600x600x20mm porcelain slabs in my garden. I need to drill 3 x 12mm holes in some of them to fix a balustrade to.
I bought an Erbauer Diamond Tile Drill Bit (12mm) from Screwfix and I've just done a test cut - which went really well (see photo).
I'm using a piece of wood to steady the bit until it gets cut into the tile.
The 'bit' came with some waxy stuff inside it which melted as it cut and (I presume) provided the necessary lubrication.
For drilling the rest of the slabs - what would you advise that I use for lubrication? Can I just use water (if so, hot or cold??) or do I need some sort of cutting fluid or something else??
I know to go steady with the bit and just use a medium pressure but, also, any other tips on drilling the slabs would be most helpful.
