Max volt drop for circuits containing lighting is 3%, 6.9v.
The maximum
'recommended' voltage drop for lighting is 3%
The only
requirement of BS7671 for voltage drop in any circuit is that
"the voltage at the terminals [of connected equipment] shall be such as not to impair the safe functioning of that equipment." - and I seriously struggle to think of any way in which
any degree of voltage drop could 'impair the safe functioning' of a light (or almost anything else)!
As I often write, even 'recommendations' regarding the degree of voltage drop in a final circuit seem to be really a bit silly, given the wide variation in permitted supply voltage.
Although I do not doubt that some people would be able to cite some very 'voltage-sensitive'(in terms of 'satisfactory functioning', not 'safe functioning') items of equipment (see ** below), I don't think that, in general, voltage drop in a final circuit will hardly ever be an issue. Provided that the impedance of the circuit satisfies the "maximum Zs" criterion (which
IS 'a requirement
, VD is extremely unlikely to ever be an issue.
[ ** if an item of equipment really is 'very voltage sensitive' then, on the basis of the 'recommendations', it would, if not lighting, have to be able to function satisfactorily down to a voltage of 204.7 volts ]
Kind Regards, John
