Hi all,
I'm looking to replace the single pane glass in my front door and side windows either side of door. The front door enters into a porch which has UPVc double glazing to the exterior. The existing wood frame is really thick, like over 2'' so I've plenty of space for a thicker double glazed option. I want to do this just to improve thermal heat loss into the un heated porch area but want to preserve the original door and frame.
I just can't seem to find any companies that supply glass only that are reasonably priced. I'm in the east midlands if that matters. I found 1 company but they wanted nearly £400 for just the two side windows which would be around 600 x 1800mm each. Seems a bit steep or am i being tight?
