i wonder if it is safe to use the neutral wire in 14/2 wring to use as hot.
i am planning to add a switch to a light on the ceiling in the basement and i want to use 14/2 and run all the wires to the light switch and use the black to feed the light switch and the neutral(white wire) to feed the electricity from the switch to the light?? i know you still can use the white wire for HOT and MUST MARK it as a HOT(live wire). is it safe to use just one 14/2 to run both ways from the light switch ????
