I have a wooden window frame, I think it is an old softwood type casement window where the glass is putty pointed from the outside into the frame. Due to condensation over the years the bottom part of the frame from the inside is slightly rotting away because the condensation trickles down the glass and then sits on the surface of bottom frame - the part where the timber touches the glass.
I scraped out any rotting wood approx 3-4mm along the length of the bottom frame. I tried to fill it with ronseal multipurpose filler but the filler never seems to set and that's after 24 hours. I think the frame is still damp and the filler is probably soaking up the water.
Whats the best way for me to fill this gap so that it can be repainted and provide a water tight seal to prevent any condensation trickling down between the glass and frame. Should i use a 2 pack filler instead and use a silicone seal to completely seal it?
Any tips and advice would be appreciated.
