Hi, I have a Zanussi Dishwasher ZDF2020 that is flashing an error on the led's. Manual says the drain is blocked.
However, if I fill the washer with 2 kettles of water and reset/start a cycle the water is drained out as normal, 5 seconds of whoosh then reduces to a trickle. So the pump must be fine and there is clearly no blockage. The machine then continues pumping for a minute but does not fill, then stops with the error.
Internal filters are clear/clean. I'm quite handy with fixing stuff myself and these forums have been a godsend with solutions but I'm at a loss to kow what is up with this machine.
Any ideas out there?
BB
BB
