ok will agree to disagree look at my edited text about pay see what you think
There's no need to agree to disagree - you just need to learn the difference between power and energy and then we'll be in agreement.
similar to i will pay you £15 an hour so the task takes 3 hours so thats £15 ??
ok a very interesting thread
i am very open to learning perhaps the choice off "h" doesnt help
ok lets think off another example a 18v 5ah battery in an hour will be 18x60x5=5400kw total capacity so perhaps the issue is they are working out the energy used as a 1 hour time frame then transferring it to a another value as in now a total divided actual time
so infarct 2 equations as in average over 1 hour to give a value off perhaps 500 total then another equation to divide the use over another time span off perhaps 2hr 45 so very sloppy and confusing as
much much easier to to say total energy used in this cycle and length off cycle so cost per hour pointless as the total is the value off the action [the wash ]
mmm if its not per hour not sure why "H" is in the equation ??? as it seems to complete equation as in time [1h] time used energy = total used ??Crude, and potentially false, analogies rarely serve the purpose of helping explain a subject. You're better off sticking to the subject itself.
If you must though, the unit of capacity for a battery is amp-hour (or watt-hour if you factor in voltage too thus indicating total energy capacity). Thus, your battery with a capacity of 5Ah (or 18x5=90Wh to put it in units of energy) could supply 5A for 1 hour, or 2.5A for 2 hours, 1A for 5 hours etc. Different amounts of power for different amounts of time.
Again though, stick with getting your head around energy consumption of washing machine programmes otherwise you risk confusing things more than they already are!
The unit of kWh is not a 'per hour' measurement (that would be kW/h). kWh represents the total energy consumed (and therefore total cost payable).
the trouble is they introduce a value that is time related rather than a total value so cannot be transferred from one meaning to an other kwh cannot be transferred without an equation as in hours times value gives your answer
kwh tells you exactly what it represents per hour it cannot have two values
total kw used is what should be used then you divide by the the hours and mins to get an answer
(I'd love to see @Mr Chibs' face when he wakes up to see this and discovers we spent the whole night talking about his little question! )
If you had smart meter and turn everything off in house and run washing machine it will tell you the cost won't it. See this in customers houses as the cost jumps when I'm about. Ha. I see them looking the tight fisted bunch. I seem to be able to use £1 of electricity easy enough in winter with heaters, fans and tools
