- Joined
- 17 Jun 2021
- Messages
- 7
- Reaction score
- 0
- Country
The black is probably leaking sealing bitumen sealing compound from the lead armoured cable.
Thanks, Harry.
Should I worry about this?
I would say that the "salutory lesson" is that we have all (certainly myself) been reminded of how misleading 'optical illusions' can be.
Thanks, Harry.
Indeed. Glass is, I believe (per the ongoing demo in the Science Museum), the same, except that it flows very very slowly (and it certainly shatters if hit!)No, it is reasonably normal. Bitumen is one of those peculiar materials which is both a liquid and a solid. Hit it hard and it will shatter, but will flow under its own weight.
I thought this had been disproven, the glass in old shop windows is thicker at the bottom because the proudction process was far from perfect in those days and the panes often varied in thickness, and it was always the bottom that was thicker because that was the sensible way to install the imperfect glass, no one would ever suggest putting the heavy bit at the top
I think you will find that the (qualitative) concept of 'glass flowing' has not been 'disproved'. What has been discredited is the once common belief (which you allude to) that such flowing was the reason why very old glass windows, particularly church/cathedral windows, and the lower parts of antique glassware, are often thicker at the bottom (the true explanation probably being as you suggest)I thought this had been disproven, the glass in old shop windows is thicker at the bottom because the proudction process was far from perfect in those days and the panes often varied in thickness, and it was always the bottom that was thicker because that was the sensible way to install the imperfect glass, no one would ever suggest putting the heavy bit at the top
