Well, if we want to go properly technical....
The valve is technically a:
screwed, 3 way, actuated, plug/ball* valve to give it its technical name as one would specify in industrial parlance.
Some people say motorized instead of actuated which i would argue is incorrect, but its clearly not a manual valve so the meaning is understood.
Some people would say 3 port instead of 3 way, again, i would think this incorrect but the meaning is obvious.
Mid-position isn't really something i would expect on a valve id. It is just one of the porting configurations (AB) that the valve can do. Some 3 way valves only select A or B, some don't.
I can't find out if the valves are plug or ball. I suspect plug, but when specifying a valve, this is probably the most important identification to have, which, ironically, these don't have.
I wouldn't be using vendor nomenclature either. Mostly, vendors are resellers of a base stock. EPH for instance call this valve a 3 port motorised valve!
TL;DR? : Call it what you wan't. just make sure you order it correctly
