Are you sure? Your excitement and running count suggest otherwise.. It's not my petition
Valid.They already tried that argument.
I was only following your words...There was no opt out
The welsh government are now blaming the councils for not opting out on roads that they felt should not be charged
Yes, but again, for all practical purposes, a road that is a 30 and has been 'opted out' to remain a 30, would never have had an enforceable 20 limit.The process the local council would have to follow is the same for setting a limit at 40mph, where a system of street lights existed
At least that, I partly agree with.The problem they face is NIMBYsm. Everyone wants the speed limit outside their house to be 20mph but not have to drive at 20mph on their commute
You seem to be struggling with the term 'blanket'I can see that we are partly misunderstanding each other.
there was no opt out.
All restricted roads had a blanket change of limit from 30mph to 20mph as per the welsh specific SI.
The welsh government argued that it was for councils to "opt out of the change". But they could not simply say - "not the B231 or the Ring Road X, please". That is because the welsh government did not change the limit by bulk applying a load of traffic orders to existing 30 limits. They had no power to set speed limits on individual roads. That is for local government (mainly). They changed the definition of restricted road.
It was therefore a blanket change. To "opt out" would have required the local authority to run a load of bulk traffic orders to set the limit back on a case by case basis. You could argue that the welsh tories, could have resisted by bulk applying traffic orders, but I think they also saw political mileage in letting the change go through. Much as Sunak allowed Khan's Ulez expansion.
2.—(1) The rate of speed fixed by section 81(1) of the Road Traffic Regulation Act 1984 (general speed limit for restricted roads) is reduced to 20 miles per hour.
You're very liberal with your misinterpreatation of the rules:It was a blanked change to the speed limit for all restricted roads. It was not limited to urban areas.
Doesn't get any clearer than:
The 20mph limit has come into force for all restricted roads, which are defined as roads with lampposts placed not more than 200 yards (about 180m) apart. They are typically located in residential and built-up areas of high pedestrian activity.
That is not a blanket policy. It's a specific targetted policy
...and back to the emotive!These are a restricted roads
If they were in Wales, the speed limit would be 20mph as a result of the SI that changed the speed limit for all restricted roads. Not just some, not just those in residential areas, not just those where pedestrians are. ALL restricted roads = blanket change - simples
